How to connect and display in-row cooling to the cabinets
  • EcoStruxure IT forum
  • How to connect and display in-row cooling to the cabinets
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 05:31 PM . Last Modified: ‎2024-04-09 02:17 AM
769
I cannot figure out how to connect and visually represent the in-row cooling devices to the cabinets that they are cooling, if that makes sense.
(CID:104174351)
Replies 5
769
Hi Sean, Can you elaborate on your questions to make sure we understand? Is your question if Data Center Operation supports Rack air containment systems? If this is the case is this unfortunately not possible in Data Center Operation. It is possible to use the hot and cold aisle containment systems. For system running without containment systems is it not possible to dedicate specific racks to a cooling units since the other nearby racks also will be influenced by the airflow. The racks might also be influenced by other cooling units unless stopped by walls or cages. But please let me know if I have misunderstood the question. Thanks Jesper
(CID:104174778)
Hi Sean McGinnis, did you see this? Best, Stine
(CID:104174783)
Thank you for the feedback.
(CID:104174784)
Hello Sean, It is not necessary to tell the model which racks a cooling unit is servicing. The model is base on StruxureWare EcoStream which will automatically calculate Inrack temperatures when a change occurs within the model. Please see the URL below that explains how accurate the cooling model may be if configured correctly Cooling Configuration Accuracy and Design Guidelines For more information on EcoStream please see the URL below http://blog.schneider-electric.com/datacenter/2014/03/04/ecostream-offers-benefits-cfd-fraction-cost... Thanks Victor
(CID:104174777)
Posted: ‎2020-07-02 05:31 PM . Last Modified: ‎2023-10-31 11:04 PM
This is a heading
