How to clear DCE client login IP's/hostname from drop down list
  • EcoStruxure IT forum
  • How to clear DCE client login IP's/hostname from drop down list
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 06:28 PM . Last Modified: ‎2024-04-03 02:59 AM
744
I recently changed DNS names and would like to clear the "Hostname/IP Address" values from the drop down list from DCE desktop client login screen.
(CID:141267744)
Hi Ryan,
There's a folder under your user account on your system that looks something like this:
C:\Users\\.isxc\7.6.0\.metadata\.plugins\org.eclipse.core.runtime\.settings
If you delete that .metadata folder, the local client info is deleted and set back to defaults. If you delete the file "org.eclipse.ui.prefs" in the .settings folder, I believe you'll remove the IP info.
Steve
(CID:141267758)
Hi Ryan,
Steve
(CID:141267758)
Posted: ‎2020-07-05 06:28 PM . Last Modified: ‎2023-10-22 02:27 AM
