How to change the look of equipment
  • How to change the look of equipment
129
72
Posted: ‎2020-07-04 02:52 AM . Last Modified: ‎2024-04-05 03:41 AM
989
is it possible to download a picture ( gif, jpeg,bmp, dwg,.... file ) or even draw one yourself and use it to change the look (front and back) of the equipment ( server, switch,storage box, bladecenter, etc... ).  Or use somekind of MIB? I have seen this in DCIMs from other vendors where the server is really configured (and shown) with fiber, ethernet cards, power supplies, etc...  . As if you take a picture of the server.
This is not only nice to have, but also very practical, more realistic and more intuïtive from a system or network administrator point of view for example.
This is also something our clients would like to see in the webclient.
regards
Tom
(CID:126880490)
  • Data Center Operation
  • Genome
Replies 6
989
Hi Tom,
It is not possible (not supported) to change the look of equipment in DCO. However, I was wondering perhaps using custom properties might be useful here.
As described here: Custom properties, if you start a property value with http:// or file://, you will create a clickable link in the list of custom properties and will also add Custom Links to the context menu for the equipment item. This allows you to store for example a photo of the equipment or any equipment documentation, or create a link to product pages.
Hope this helps,
Kind regards
(CID:126880506)
Thank you for your quick reaction Jef.
Is there an upgrade foreseen in the, hopefully near, future to have this feature?
The client(s) ( and me )  would like to have a realistic rack view. Going into the properties field for each server seperately is not a solution to this issue. It could help of course, but doesn't change anything about the initial request.
You say : not supported. So, maybe there is somekind of workaround?
(CID:126883045)
You are welcome, Tom
Sorry, as far as I know there is no workaround - it is basically not possible for a DCO user to change the look of equipment. If you wish, I can capture this as a feature request for you, or you might want to post one here:  Feature requests
Kind regards
(CID:126883115)
I posted a feature request.
Thx
(CID:126883134)
Thanks, Tom
Kind regards
(CID:126883355)
Posted: ‎2020-07-04 02:52 AM . Last Modified: ‎2023-10-22 02:26 AM
