How to change the keyboard used on the console of DCO (after installation)?
  • How to change the keyboard used on the console of DCO (after installation)?
129
72
Posted: ‎2020-07-05 01:15 PM . Last Modified: ‎2024-04-04 12:36 AM
1138
The customer wants to move from azerty to querty.
During install he selected only azerty.
How can he change/add a keyboard (for use in the console) ?
(CID:134687319)
  • Data Center Operation
Hi Eduard,
I think you can do it by using the loadkeys command (for temporary settings) and/or localectl command for permanent settings. If it should be unavailable on your system, then install the kbd package first.
ssh log in to the server, and:
sudo -i
yum install kbd
For example the following (loadkeys uk) will temporarily change systems keymap to UK:
loadkeys uk
Loading /lib/kbd/keymaps/i386/qwerty/uk.map.gz
To list all available keymaps on your CentOS system run:
localectl list-keymaps
That will produce a long list:
find the layout that you want to change to (ex. US), and then enter the following command to permanently change to eg. us keymap:
localectl set-keymap us
And then to confirm your permanent settings execute the localectl command without any argument:
localectl
Kind regards
(CID:134687384)
Hi Eduard,
sudo -i
yum install kbd
loadkeys uk
localectl
Kind regards
(CID:134687384)
Posted: ‎2020-07-05 01:15 PM . Last Modified: ‎2023-10-22 02:26 AM
