How to backup and restore Struxureware portal configuration file
  • EcoStruxure IT forum
  • How to backup and restore Struxureware portal configuration file
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 07:54 AM . Last Modified: ‎2024-04-10 01:37 AM
1377
Is it possible
" Schneider's struxureware Portal can provide backup and restore function ?
I would like to know  yes or not
Thanks.
(CID:89063766)
  • Portal
Posted: ‎2020-07-02 07:55 AM . Last Modified: ‎2024-04-10 01:37 AM
1377
I've send you the password for your setup offline.
Once the connection is setup (in screenshot I have pgAdmin in the same machine as the portal server)
And the servers section will then show the list of databases
(CID:89555487)
Replies 10
1377
Hi Doody,
The StruxureWare portal can be manually backed up and restored following the instructions found here:
http://dcimsupport.apc.com/display/Portal/StruxureWare+Portal+backup+and+restore
/Søren
(CID:89063781)
Thanks soren
(CID:89063782)
Hi Soren
I got some problem. When i try to DB back-up of Portal.
First  I couldn't find DB is named "lportal "
I am attached my screen shot
Also when i try to connect to the server (Double click it ), The server ask for password
Let me know the solution for solve it
Database backup
Using pgAdmin
  1. Start pgAdmin (Windows: Navigate to Start -> All Programs -> PostgreSQL 9.1 -> and launch pgAdmin III )
  2. Select Servers -> Databases -> lportal (if asked for password please contact EcoStruxure IT Help Center)
(CID:89555409)
1378
(CID:89555487)
Will this provide a full backup of the portal, both content and configuration?
(CID:92537596)
The guide http://dcimsupport.apc.com/display/Portal/StruxureWare+Portal+backup+and+restore describes backup of both content and configuration. The database backup will not cover the configuration backup which is done by copying/backing up a folder from the old installation.
(CID:93192227)
Just to confirm, so there is no way to have a (automated) scheduled backup of both content and configuration?
(CID:93192292)
Not from the Portal installation it self. However using a 3rd party backup application for database/file backup I would expect this to be standard functionality.
(CID:93192333)
Hi All,
I also need database password for backup. Because of i can not login in my portal so i will reboot it.
Regards
Kerem
(CID:105469871)
Posted: ‎2020-07-02 07:56 AM . Last Modified: ‎2023-10-31 11:03 PM
