Posted: β2020-07-02 07:53 AM . Last Modified: β2024-04-10 01:38 AM
(CID:89063735)
Yes. There is an issue in 7.2.2 DCE with Galaxy 7000 UPSes.
You have to ask APC to give you appropriate patch.
7.2.0 was Ok, not sure about 7.2.4.
(CID:89063737)
(CID:89063737)
(CID:89063740)
(CID:89063743)
(CID:89063748)
Posted: β2020-07-02 07:54 AM . Last Modified: β2024-04-10 01:38 AM
(CID:89063754)
Posted: β2020-07-02 07:54 AM . Last Modified: β2024-04-10 01:37 AM
I will run a test with DCE 7.2.4 and come back to this forum.
(CID:89063751)
(CID:89064040)
This issue was resolved in DCE 7.2.4. The issue was only present on 7.2.2 for 3rd party devices. There is a patch that can be applied to fix the issue on 7.2.2.
The link for the patch is below:
https://schneider-electric.box.com/s/y649mwel9y6wd3zv4reu
B
(CID:89063756)
Just to give some feedback. I have tested the Galaxy 7000 with DCE v7.2.4 and it works ok. The sensor reading issue has been resolved as Breda put it to this forum.
(CID:89063761)
Posted: β2020-07-02 07:54 AM . Last Modified: β2023-10-31 10:59 PM
