Posted: 2020-07-03 09:52 PM . Last Modified: 2024-04-07 11:33 PM
(CID:123348787)
Posted: 2020-07-03 09:53 PM . Last Modified: 2024-04-07 11:33 PM
Hi Eric,
Take a look at the video in k-base FA177081.
It should give you all you need on the DCE side.
Steve
(CID:123348799)
I looked at the video and found some new stuff like unchecking the Tap Registration box and I removed the transfer settings. I also did a global search for the IP address in the entire data base. Nothing I have tried seems to be working. The end user says there are no duplicate IP addresses in use. I reconfigured the port access to match CBS network Port 80 SNMP V1. I can Ping the network card but cannot Telnet into it.
Do you have any other suggestions
(CID:123348860)
Hi Eric,
Check out this kbase:
It may help in troubleshooting your issue.
Steve
(CID:123348879)
Posted: 2020-07-03 09:53 PM . Last Modified: 2023-10-22 02:25 AM
