Particle sensor NBES0201 compatibility
  • Particle sensor NBES0201 compatibility
129
72
Posted: ‎2020-07-03 09:53 PM . Last Modified: ‎2024-04-07 11:33 PM
859
Hello team,
Since the pod NBPD0122 has been phased out, is there any other sensor that works with particle sensor? I didn't find any information about this on NBPD0155 manual.
Thanks!
(CID:123348850)
  • NetBotz
Hi Alexander,
No, that sensor was designed for the old version 2 NetBotx 500, 420, and 320 units. It has a PS2 style connection that is not compatible with the RJ45 connectors on the current units (or the 150 or 155 pods). The only way to use it with a current unit is a 550, 570, 450, or 455 NetBotz appliance that has a USB port, the NBPD0122 version 2 sensor pod and then the particle sensor as the NBPD0122 has the PS2 style connection. If a reseller can't get one of those pods, I'm sorry but you're out of luck. I had heard rumors about a PS2 to RJ45  coupler or an RJ45 style particle sensor but neither has gone any farther than rumor.
Steve.
(CID:123348854)
Hi Alexander,
Steve.
(CID:123348854)
Posted: ‎2020-07-03 09:53 PM . Last Modified: ‎2023-10-22 03:32 AM
