Posted: 2020-07-03 09:52 PM . Last Modified: 2024-04-07 11:34 PM
Does anyone know if Data Center Expert 7.2 is compatible with Windows 10?
(CID:123348647)
Posted: 2020-07-03 09:52 PM . Last Modified: 2024-04-07 11:33 PM
Hi Jeff Eppinette,
Cory McDonald is certainly right: officially support for DCE-client 7.2.x under MS Windows 10 is not declared.
However, in practice, I was able to normally install the DCE-7.2.1-53 client on MS Windows 10 Home x64 (1703) and work normally.
Therefore, if you really need this version of DCE, then I do not see any denials for this: try and use 😀.
With respect.
(CID:123348845)
Jeff,
Data Center Expert desktop client compatibility for specific versions can be found within each versions release notes on the following page:
https://dcimsupport.apc.com/display/public/SWDCDOC/PDF+Library#PDFLibrary-ReleaseNotesadditional
Windows 10 compatibility was not added until Data Center Expert 7.4.X.
I recommend contacting your local technical support for them to verifiy your software support contracts and then provide you with the necessary upgrade files to come up to a compatible version.
Best Regards,
Cory
(CID:123348656)
Hi Jeff Eppinette,
With respect.
(CID:123348845)
Posted: 2020-07-03 09:52 PM . Last Modified: 2023-10-22 02:48 AM
