Posted: 2020-07-02 08:30 AM . Last Modified: 2024-04-10 01:29 AM
(CID:89555766)
Hi Brenda,
There are 2 ways to get peak power based on measured data. Depending at which level you would like to see the data.
Both reports are based on capacity history data (KPIs) which is collected daily (by default) Capacity History (KPIs) over Time
At Rack level:
Using the capcity history report to present the "Measured A/B-feed peak" data.
At Room level:
Using the power Capacity report.
More info can be seen here: Capacity Reports (Both reports require the capacity license to be in place.)
(CID:89555828)
Posted: 2020-07-02 08:30 AM . Last Modified: 2023-10-31 11:02 PM
