Posted: 2020-07-02 08:29 AM . Last Modified: 2024-04-10 01:29 AM
(CID:89555749)
Posted: 2020-07-02 08:30 AM . Last Modified: 2024-04-10 01:29 AM
Yes it does - during development the server is often tested on virtual machines. Make sure that the virtual machine follows the same machine specifications as suggested for dedicated servers.
See here for the System Requirements.
(CID:89555757)
Yes it will. I believe since 7.3 they have strongly encouraged users to move to a virtual environment. Also they have added clustering and fail-over options to the configurations.
We are running a lot smoother on a VM. Make sure you follow their guide posted (in the 7.2 documentation I believe) for adding VMtools. It is not straight forward and I have added comments and links to the bottom of the page as well.
Actually looks like they updated: Optimizing performance of StruxureWare Data Center Operation running on VMware
(CID:89555761)
Posted: 2020-07-02 08:30 AM . Last Modified: 2023-10-31 10:46 PM
