Posted: 2020-07-02 08:29 AM . Last Modified: 2024-04-10 01:29 AM
(CID:89555685)
Hi Troy,
NetBotz has a special dedicated port for the Beacon, you can connect the beacon to the NetBotz and have NetBotz monitored by your DCE.
Felix
(CID:89555703)
Its plugged in but I can't seem to find it in the proper DCE menu.
(CID:89555733)
Hi Troy, welcome to the community! When you comment on an answer, please use a "comment" function instead of "answer" which is reserved for giving a direct answer to a question. Thank you.
(CID:89555752)
Hi Troy,
Is the Netbotz device discovered successfully by DCE? If so, you should be able to right click on the Netbotz device to which the beacon is connected and "View Device Sensors". You can change the state of the Beacon to on and off in this section. What are you trying to achieve with the Beacon? Do you want to set it off to alert on a certain alarm? If you want to configure the Beacon, i would advise doing this via Advanced View (if you have a Netbotz 200, you can do this through the web interface). What Netbotz model do you currently have?
There are details in how to configure sensors to alert on the below manual (page 129):
http://www.apcmedia.com/salestools/LSCZ-7B7KY3/LSCZ-7B7KY3_R6_EN.pdf
If its a Netbotz 200, details on the manual on page 42
http://www.apcmedia.com/salestools/JSAI-7BRLGR/JSAI-7BRLGR_R0_EN.pdf
B
(CID:89555755)
Posted: 2020-07-02 08:29 AM . Last Modified: 2023-10-31 11:01 PM
