Posted: 2020-07-02 08:30 AM . Last Modified: 2024-04-10 01:29 AM
We have two data centre's and both is populated in operations - how do I filter the alarms so I just see the alarms for one data centre?
(CID:89555771)
If you only have 1 of the Data center's tabs open, you should only see servers and alarms for that specific site.
(CID:89555789)
Posted: 2020-07-02 08:31 AM . Last Modified: 2024-04-10 01:29 AM
Hi Craig,
There are several ways to filter alarms.
I guess the easiest way would be to use the linking in the "Alarms" view. This will only show alarms from the current asset/rack/room/location being selected. Showing Alarms for Selected Equipment Only
Another way is to restrict this using the user rights section. Only people with access to a given room see alarms from that room (based on where the alarming device is associated) Managing User Rights
Finally it is possible to filter in the DCE integration based on the user used for retrieving data from the DCE. This would mean only alarms from DCE a given user is allowed to see will be shown in DCO. Configuring StruxureWare Data Center Expert Integration
Hopefully this solves your question otherwise please let me know.
(CID:89555842)
Posted: 2020-07-02 08:31 AM . Last Modified: 2023-10-31 11:02 PM
