How change the ip address whitout lossing history record from sensors?
  • How change the ip address whitout lossing history record from sensors?
129
72
Posted: ‎2020-07-04 01:48 AM . Last Modified: ‎2024-04-05 04:01 AM
1005
We need change 1000 ip address from many sensors whitout lossing the history record. Is this possible? How?
Thanks.
(CID:126174930)
  • NetBotz
1004
Sebastian,
When an IP address is changed, the device would need to be rediscovered.  If the history needs to be kept, the old IP can be kept in the system for records, but the device will now be using two device node licenses (one for the old IP and one for the new IP).  There is no way to consolidate the old IP information under the newly discovered device.
Cory
(CID:126174939)
Replies 4
1005
Sebastian,
Cory
(CID:126174939)
FYI, I've added this post to the existing enhancement request.
(CID:126174969)
Posted: ‎2020-07-04 01:49 AM . Last Modified: ‎2024-04-05 04:01 AM
Thank you very much...
(CID:126175079)
Posted: ‎2020-07-04 01:49 AM . Last Modified: ‎2023-10-22 02:19 AM
