Posted: 2020-07-04 01:47 AM . Last Modified: 2024-04-05 04:01 AM
Dear Experts,
During the WMI Discoveries I only discovered one server, and I checked the logs for the other servers and I found the following message"WMI - Succesfully connected.VMware guest encountwred, not saving device" any idea how to fix this issue ?
BR,
Sameeh
(CID:126174746)
ITO's focus for discovery is to physical servers so when a virtual server like a vmware guest is found it will be skipped. If you want to discover VMware guests try discovering your VMware servers (ESXI hosts) using the VMware protocol, there is a included guests checkbox which will return discovered guest info as well as the host info.
ITO will also skip discovery of other guest types including hyper-v, kvm, virtualbox, and so on.
Regards
Greg Sterling
(CID:126174761)
Posted: 2020-07-04 01:47 AM . Last Modified: 2023-10-22 01:31 AM
