How can you connect network devices in DCO using QSFP to SFP fiber cable
  • EcoStruxure IT forum
  • How can you connect network devices in DCO using QSFP to SFP fiber cable
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 06:03 AM . Last Modified: ‎2024-04-08 11:09 PM
623
This is a 40 GB Fiber to 4 - 10 GB Fiber connections
(CID:108825419)
  • Data Center Operation
Hi Russell Singh, thanks for posting! Let's see who can be of assistance here. Best, Stine
(CID:108825607)
Hi Russell,
In following example I have configured two patch panels (I'm using DCO 8.0): one with "QSFP" and the other with "SFP" network ports:
by right clicking on device > Properties > Network,
"New..." and then Name it as "QSFP" and select Type as "Fiber":
Similar configuration for the other device:
Additional to those devices (patch panels) I do also have a switch unit with both "QSFP" and "SFP" configuration.
As illustrated, by using the "Connection tool" I can easily make a network connection between all three devices:
Hope this helps,
Kind regards
(CID:108825942)
Posted: ‎2020-07-03 06:03 AM . Last Modified: ‎2023-10-31 11:01 PM
