Posted: 2020-07-02 10:36 AM . Last Modified: 2024-04-10 12:49 AM
How can we change the background color portlet by portlet in the portal server? This is a customer request and they wanna have for the different portlets change the backgroundcolor from white to something different.
(CID:93915267)
Hi Brunner, we will look into it, thanks for posting.
(CID:93915349)
Hi Ueli,
It is not possible to change the background color of portlets in the StruxureWare Portal.
Technically it could be done but it would require custom developed portlets which must be created based on quotation.
It is possible to change the color theme of the Portal however that is affecting the graph, borders etc. coloring and not the background. The theme coloring is found in the "control panel"->"Site Pages"
(CID:93915385)
Posted: 2020-07-02 10:37 AM . Last Modified: 2023-10-31 11:00 PM
