DCO Network Connection Between 2 Different Rooms
  • EcoStruxure IT forum
  • DCO Network Connection Between 2 Different Rooms
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 10:37 AM . Last Modified: ‎2024-04-10 12:49 AM
589
I want to create a network connection between 2 cabinets which are located in 2 different rooms in the same building. Is this possible? How can I create that connection?
(CID:93915269)
  • Data Center Operation
589
Hi Kaan,
This is possible by interconnecting the patch-panels in the cabinets you need to be networked together.
Here is a way to achieve this:
a. Right click on the patch panel & go to properties.
b. Under "Back Connections" sector, press the button "Connect To"
c. You shall be able to select the exact Room, Row, Rack, Patch Panel, Name, Type & Start Port from there.
I hope this helps.
(CID:93915346)
Hi Kaan, Further to the above answer it is also possible to create a route directly from a device in one cabinet in a room to a device in a cabinet based in another room. This can be done be using the "-> - outside of rack" option which then will present other rooms in the solution. However make sure the room(s) you want to connect to are open in the client since they need to be loaded in order to be presented in the list of available connection.
(CID:93915386)
Posted: ‎2020-07-02 10:37 AM . Last Modified: ‎2023-10-31 10:50 PM
