How can I check how many DCE node licenses we have used?
  • EcoStruxure IT forum
  • How can I check how many DCE node licenses we have used?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 01:42 PM . Last Modified: ‎2024-04-04 12:25 AM
1110
(CID:134693400)
Replies 7
1110
Hi Mr. Muro,
Good day.
The number of used nodes can be found under Server Administration Settings (System->License Keys)
You can refer to the "Used Node Count" column to know the number of nodes in use in a node license, as shown in the photo below.
I hope this answers your question.
Justine Chester
(CID:134693408)
(CID:134693423)
It's blank
(CID:134693425)
Hi Mr Muro,
I think it is best to contact your local technical support so they can assess what could be causing this.
At the same time, you can also provide them with your login details (DCIM assets page), so they can check how many licenses can be applied to your DCE server.
I hope this helps.
Justine
(CID:134693921)
Logon to the thick client.  Select System -> System Administration Settings -> License Keys.  There you will see a list of the applied Licences, including the licence type and amount of nodes used.
(CID:134693412)
Posted: ‎2020-07-05 01:43 PM . Last Modified: ‎2024-04-04 12:25 AM
Dear Mr Muro,
Please, tell us if you could solve this problem or not?
With respect.
(CID:137103349)
Posted: ‎2020-07-05 01:43 PM . Last Modified: ‎2023-10-22 02:18 AM
