DCO Offline Demo vboxnet0 error
  • DCO Offline Demo vboxnet0 error
126
65
Posted: ‎2020-07-05 01:43 PM . Last Modified: ‎2024-04-04 12:25 AM
1002
I am trying to run DCO offline demo after setting the Host only network IPV4 to 192.168.56.1 and subnet mask to 255.255.255.0
When I run the virtual machine, I get the error in snapshot. Any suggestions how to remove this error and run the virtual machine.
(CID:134693599)
  • Data Center Operation
It was a simple two step fix
  1. I  removed old versions from C:\Users\VirtualBox VMs
  2. enabled Intel Virtualization Technology VT-x  from BIOS and reloaded the Offline_827 file
The demo is working fine now.
(CID:134694766)
Replies 5
1002
Hi Adeel
Check your VirtualBox (not VM) network settings.
Then make sure your VM network is properly configured
Cheers
Ed
(CID:134693933)
Hi Ed,
I have performed these steps, but I cant seem to get "vboxnet0" instead I get the option of "VirtualBox Host-Only Ethernet Adapter" and the error is still the same
(CID:134694011)
Adeel, I recommend you change your Virtual Box and VM configurations as shown.
Ed
(CID:134694711)
(CID:134694766)
Posted: ‎2020-07-05 01:43 PM . Last Modified: ‎2023-10-22 01:39 AM
