How DCE Log file are stored by the application ?
  • How DCE Log file are stored by the application ?
127
65
Posted: ‎2020-07-04 04:33 PM . Last Modified: ‎2024-04-05 12:11 AM
659
Thougtht that purge settings will apply to log files, but i'va never purge thresholds.
I can't see files older than 10 days.
Thanks for any clarification
Benoit
(CID:130095322)
Hi benoit rohart
When purging, these are the options you can configure:
The check boxes for things like all surveillance data and Sensor data etc are settings for a manual purge. Are you manually purging data or are you allowing the system to automatically purge based on the putge settings on top?
I'm unsure to what you'er referring when you say you've never purged "thresholds".
To what are you referring exactly when you say:
"I can't see files older than 10 days." What files?
Are you using a VM? If so, how many drives of what size are being used?
How many devices and how many cameras do you have?
What are the percentages of different data for total repository usage?
Steve
(CID:130095328)
Dear benoit.rohart,
Have you been able to solve your problem, or do you have any more questions about it?
With respect.
(CID:130680481)
Posted: ‎2020-07-04 04:33 PM . Last Modified: ‎2023-10-22 02:17 AM
