Posted: 2020-07-05 11:23 PM . Last Modified: 2024-04-03 12:09 AM
Dear support,
Hello, can you help me in knowing the process to modify a DDF ZTE CSU-ZXDU by SNMP.
The decimal point is covered, example: actual measurement in equipment 55.4 V and measurement in DCE 554 V.
Another example would be: measurement in equipment 285.5 A Amp and in DCE 2855 Amp.
The variables that I need to modify would be the following:
"SMR Ouput Voltage" this setting would apply to all rectifiers.
"SMR Total Current".
thanks for your support
(CID:151063894)
Posted: 2020-07-05 11:24 PM . Last Modified: 2024-04-03 12:08 AM
Dear Gustavo,
Please submit your device DDF modification request on below URL.
https://ddf.ecostruxureit.com/
I hope this helps.
Bala
(CID:151063953)
Hi Bala
Thanks for your support
Gustavo
(CID:152077001)
Posted: 2020-07-05 11:24 PM . Last Modified: 2023-10-22 02:15 AM
