Getting DCE to backup to my local hard drive via VPN
  • EcoStruxure IT forum
  • Getting DCE to backup to my local hard drive via VPN
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 05:24 PM . Last Modified: ‎2024-04-03 03:22 AM
951
I am not able to get DCE to backup to my local hard drive via VPN to the network. Does anyone have any suggestions.
(CID:140219775)
Replies 4
951
Hi Russ,
Have you tried backing up locally / same subnet as DCE? That’s your first best troubleshooting step. If the issue is with a full backup, you may also want to try a config only backup. If you have a server or laptop local to the DCE server and it works but your VPN drive does not, it could be anything from timeouts to firewalls to a host of other network related issues. I’m specifically pointing to that sort of issue solely because you are specifying VPN.
A packet capture may help in isolating issues but you’ll probably have a better chance of figuring that out with the local network people than DCE troubleshooters.
Steve.
(CID:140219791)
Not yet. I am in another state so doing anything locally is difficult. I have turned off all firewalls and antivirus on my PC, but I cannot get the drive to mount. I found an article on how to perform a local backup but while the article made sense, it did not work in my case and I assume because I am VPN into the network instead of local.
(CID:140220049)
Hi Russ,
If there's a system local to the DCE server, perhaps you could remote into that system and usethat share as a test so the mound doesn't have to go through the VPN, only the remote connection to the other server does.
Steve
(CID:140220051)
Posted: ‎2020-07-05 05:25 PM . Last Modified: ‎2023-10-22 02:09 AM
