How do I monitor rate of increase in current?
  • How do I monitor rate of increase in current?
129
72
Posted: ‎2020-07-05 05:25 PM . Last Modified: ‎2024-04-03 03:22 AM
1195
DCE has a function to allow an alarm tied to a rate of change in temperature.
So the function to look at a number and compare it to the number in 5 minutes exists. There is nothing special about temperature numbers.
I'd like to be able to monitor the current on a PDU or breaker module to look out for sudden changes.
The situation is this - a cabinet typically operates at a current draw of 6-8 amps per phase... phase 3 has a fairly sudden jump of 3 amps and it stays there for a few days....
even if that isn't causing a problem with my capacity, it is something that would be good to know, if I could get an alert. Right now, I can run a report and look at a trend graph every day, or I can export data and do some manipulation....
But, I don't have any function in DCE that will help me reduce the laborious processes mentioned... I'd like to see a function that allows me to set an alert for sustained load changes that are out of the normal.
(CID:140219797)
Replies 7
1195
Dear Eric Clark,
From your question:
Do you mean the threshold values Rate of increase and Rate of decrease? If so, then why can't you use the same threshold values for current or power? For example, I have been doing this for a long time.
With respect.
(CID:140707557)
No, you are right, I always get sort of lost in their process of creating alarms - forgot there was an extra layer ... thanks
(CID:140707565)
Dear Stine Hansen,
Tell us please, where did the option for the comment Convert to answer?
Very thanks for the support.
(CID:140707561)
Hi spezialist,
I have changed your comment to an answer.
Stine
(CID:140707567)
Ok, very thanks for the support :-).
(CID:140707717)
Dear Eric Clark,
Tell us, please, did you solve your question or not?
With respect.
(CID:141269255)
Posted: ‎2020-07-05 05:25 PM . Last Modified: ‎2023-10-22 02:21 AM
