Genome enclosure match for Proliant SL210t Gen8: 1U node Blade
  • EcoStruxure IT forum
  • Genome enclosure match for Proliant SL210t Gen8: 1U node Blade
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 10:30 AM . Last Modified: ‎2024-04-10 12:52 AM
880
I have a HP ProLiant 2500 Gen 8 enclosure with 4 SL210 Gen8 1U Node blades. In the Genome library i find both the SL210 Gen 8 blade and the ProLiant T2500 but the blade wont fit into the chassis. Any suggestions on what might be the reason they don't match?
Regards
André
(CID:93915014)
  • Data Center Operation
879
Hi André,
The reason for the blades not fitting in the enclosure is that the enclosure is a storage enclosure.
The HP ProLiant 2500 Gen 8 enclosure is currently not in the Genome library of DCO.
This means a enclosure must be created manually.
I would recommend creating the enclosure based on the "HP ProLiant BL E-class Server Blade Enclosure"
I added that enclosure to my Genomes and then changed it according to the specs I found giving the following:
Once adding  the device to the model it will look something like this where the blades then can be added to the 4 slots/bays by dragging and dropping from the genomes:
(CID:93915081)
Replies 4
Hi André, we will look into it, thanks for sharing.
(CID:93915071)
880
Hi André,
(CID:93915081)
Thanx Sören!!
(CID:93915082)
Posted: ‎2020-07-02 10:30 AM . Last Modified: ‎2023-10-31 10:59 PM
