Power capacity and capacity history reports coming empty in DCO 7.3.5
  • Power capacity and capacity history reports coming empty in DCO 7.3.5
129
72
Posted: ‎2020-07-02 10:31 AM . Last Modified: ‎2024-04-10 12:52 AM
728
When we generate reports for power capacity and capacity history there is no data and showing empty field.
(CID:93915040)
  • Data Center Operation
Replies 5
The report is based on data collected over the last 24 hours, so the server must have been running for at least 24 hours. Do you see a red cross or do you see a graph without data? Does the report show data if export it to for instance pdf?
(CID:93915041)
Posted: ‎2020-07-02 10:31 AM . Last Modified: ‎2024-04-10 12:51 AM
Shemil,
Please look at the previous question on the same topic:
Christian
(CID:93915054)
728
Hi Jesper,
The server is at a customer site and its working since months.Report Error.JPG
Screen shot attached for power capacity report. I exported to pdf and yes its giving me the report.
Can you advise why its not appearing here and only when exported?
Shemil
(CID:93915105)
You will need to make sure the customer has write access to this directory C:\Users\"username"\AppData\Local\Temp Do they have Internet Explorer installed on their computers? If this is an older version then please instruct them to upgrade to a newer version. Thanks Jesper
(CID:93915108)
Posted: ‎2020-07-02 10:31 AM . Last Modified: ‎2023-10-31 11:29 PM
