Posted: 2020-07-02 02:31 PM . Last Modified: 2024-04-09 04:10 AM
We currently have an old Genome folder in our local library that was brought across from a migration, is there anyway to log on to the DCO server and take a copy of this folder so I can delete the instance in DCO (as I don't want people using Genomes from within it)? If needed again (as it has Genomes that are not in the global library) I could restore?
(CID:99157655)
Hi James!
You can export your Genomes via File -> Export -> Genomes menu. DCO creates archive file for you with model descriptions and folders structure.
And when you need, you can import it back. If you choose manual merge, when import, you can point models you want to import. It can be one or two servers for example.
(CID:99157730)
Hi James!
(CID:99157730)
Thanks Valentin Kozlov that worked.
(CID:99157741)
Hi James In addition to Valentins answer please be aware that there might be changes to the Genomes from version to version. Therefore the export will be version depended. However it can be work around (if needed) by importing the genomes before updating to the next version where the export then can be done again. /Søren
(CID:99157743)
Posted: 2020-07-02 02:31 PM . Last Modified: 2023-10-31 10:59 PM
