Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-03 03:06 AM . Last Modified: 2024-04-09 12:04 AM
hello all
I need your help. I did the installation of the DCO client 7.5 on a windows 7 laptop, but it doesn't launch, it keeps loading and it never connects.
Unfortunately I don't have access to the laptop as it belongs to a manager, I only have available his application log which mainly contains the following lines.
I appreciate your help or suggestions. We're in the same network and I don't have this issue in my laptop, his installation is fresh but is displaying this error. Any hint of what would be the problem (network, operating system, client, etc, is appreciated)
2016-05-11 11:18:12,299 INFO [com.apc.sma.client.Application] (ModalContext) Running server version 7.5.0.42470 (Release) 2016-05-11 11:18:12,299 INFO [com.apc.sma.client.Application] (ModalContext) Client cache under: file:/C:/Users/user/.isxo/7.5.0-42470-8540c/Operations/
2016-05-11 11:21:41,814 WARN [com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl] (Model Thread 0) Retrying JMS connection. com.apc.dsmf.client.webservices.event.QueueRemoteEventException: Unable to subscribe for events. This is likely due to a network issue. See http://www.dcimsupport.apc.com for information on which ports need to be open and how to check it., caused by: java.lang.RuntimeException: Failed to download and/or install client side AOP stack, caused by: org.jboss.jms.exception.MessagingNetworkFailureException: Failed to download and/or install client side AOP stack 2016-05-11 11:56:59,819 ERROR [com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl] (Model Thread 0) Giving up on retry 2016-05-11 11:56:59,825 ERROR [com.apc.sma.client.Application$EclipseToLog4jLogListener] (main) Error creating startup input (loading) [org.eclipse.core.runtime] com.apc.dsmf.client.webservices.event.QueueRemoteEventException: Unable to subscribe for events. This is likely due to a network issue. See http://www.dcimsupport.apc.com for information on which ports need to be open and how to check it. at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueue(QueueRemoteEventServiceImpl.java:266) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:198) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:204) at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.
(CID:106205136)
Posted: 2020-07-03 03:07 AM . Last Modified: 2024-04-09 12:04 AM
Hope this helps,
Kind regards
(CID:106205149)
Hope this helps,
Kind regards
(CID:106205149)
I have met the same issue. As Jef mentioned, it is network problem. I reset my network as follows.
Step 1) Turn off the McAfee firewall
Step 2) Reset NIC
Step 3) only then I started my DCO and DCE running on VMware workstation
the DCO client runs without any problem. Thanks
(CID:106206431)
Posted: 2020-07-03 03:07 AM . Last Modified: 2023-10-31 10:59 PM
