Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-02 11:47 PM . Last Modified: 2024-04-09 01:06 AM
Hi I am seeing more and more false alarms generated by NetBotz. for instance below is graph showing temp warning alert at 25.6, however the threshold is set as a range threshold min 16, max 28
TIA
Mike
(CID:105465695)
Hi Mike,
I confirm: we also repeatedly had just the same incidents. I did not understand the reasons of this bug. However, I can confirm that when we migrated from NetBotz 450 to the DCE server, the above specified bug did not appear any more.
Watch also a post : it seems to me, both there and here the reasons and symptoms of a bug are identical.
Very thanks for the support.
(CID:105465747)
Hi Mike,
I've seen this on random customer's systems but have not been able to isolate it with troubleshooting. Have you updated to the latest NetBotz 4.5.1 release? There are somewhat similar issues that have been addressed in this new revision and it would be good to know if this update effects this issue in any way.
Steve.
(CID:105465760)
Posted: 2020-07-02 11:48 PM . Last Modified: 2023-10-31 10:58 PM
