Posted: 2020-07-02 06:38 PM . Last Modified: 2024-04-09 01:53 AM
Please advise where I'm going wrong in this Excel load.
P.S. The backup of my DCO model is about 350MB so uploading may be difficult
(CID:105457856)
Hi Ed It seems that PDM3532IEC is the model name of a breaker module - but it should be a breaker in the setup you are using in the template.xls file. If D/A-4/Z1 is a modular PDU, you should use the sheet "Modular PDU example" in the downloadable template as the template sheet instead - otherwise the breaker model name must identify a breaker, e.g. like model name "32A 3P Generic Breaker". The bad error message will be fixed in the next release. Regards, Ulrik
(CID:105458032)
Hi Ed
The error could indicate that there is an issue with either the model name of the rack-mount PDU or the breaker model name. Could you export the custom catalog via File -> Export -> Genomes and attach that - then we can try to find out?
Ulrik
(CID:105457888)
genomes.cat attached
(CID:105457973)
(CID:105458032)
Posted: 2020-07-02 06:38 PM . Last Modified: 2023-10-31 10:58 PM
