DCO modelling wall/ceiling mounted cooling unit
  • EcoStruxure IT forum
  • DCO modelling wall/ceiling mounted cooling unit
124
65
Thumbnail of EcoStruxure™ IT Expert
40
Thumbnail of EcoStruxure IT Design CFD
26
Thumbnail of Data Center Expert
Data Center Expert
6
Load more
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:38 PM . Last Modified: ‎2024-04-09 01:53 AM
595
Hi Team,
Two questions:
1.How do we model either a ceiling mount or wall mount cooling unit like FCU?
Those cooling units are not standing on the floor.
2.The 3D calculated modelling, how can we set to show calculation from either one of the cooling?
We have a customer where they are using a mix of cooling unit of InRow
and Daikin's VRV, air cooled cooling -which is wall mounted like sample picture below.
InRow is to provide cooling during day time, whereas VRV is for the evening.
Daikin VRV:
-The Condenser unit (CU) is outside of the data center, typically on the roof.
-The Fan Coil Unit (FCU), is within the dc, either ceiling mounted or wall mounted
Thanks!
(CID:105457859)
  • Data Center Operation
Replies 4
595
HI Christoferus!
I think that you can try to model it with vertical grills on the walls.
But I have no idea how to split it in time 🙂
For 3D calculations you can disable (deactivate) InRow units for a while.
(CID:105457919)
Hi Valentin, Thanks for the suggestion. Will try that as alternative The actual unit is protruding out from the wall tough, so the 3D is not accurately representing that.
(CID:105458251)
Posted: ‎2020-07-02 06:39 PM . Last Modified: ‎2024-04-09 01:53 AM
Hi, Have you managed to resolve the issue with FCU?
I have same problem with  two electrical rooms.
(CID:133371301)
Posted: ‎2020-07-02 06:39 PM . Last Modified: ‎2023-10-31 10:50 PM
