Posted: 2020-07-03 04:54 AM . Last Modified: 2024-04-08 11:31 PM
Is there any way to give equipment an 'owner'? So if a server for example had to be moved, it's owner could be easily found and contacted.
Part two: can an owner's name be put into the search box and a list of their servers be brought up?
(CID:106892148)
In DCO, You can create a custom property for this. This custom property can then become a searchable field in the equipment browser tab.
(CID:106892153)
(CID:106892153)
You could also potentially use Tags (available in DCO Capacity) or assign a customer (DCO CoLo)
Cheers
(CID:106892335)
Posted: 2020-07-03 04:54 AM . Last Modified: 2023-10-31 10:56 PM
