Posted: β2020-07-06 01:00 AM . Last Modified: β2024-04-02 11:22 PM
Dear team,
I am trying to configure DCE email notification using smtp.gmail.com but smtp server is not reachable. You kind support is required and error screenshot is attached.
(CID:153944202)
Posted: β2020-07-06 01:01 AM . Last Modified: β2024-04-02 11:22 PM
Dear Muhammad Shahzad,
According to Michael Hanseman response from post , you must:
I would use Gmail for testing. If you don't have a Gmail account already, it's free and easy to set one up.
Settings you need for the device.
Port 587
SSL enabled
Username and password.
Depending on the environment you may need to open port 587 outbound on the customer firewall/UTM.
Hope this helps you.
With respect.
(CID:153944444)
Hi Muhammad Shahzad,
Can you please post a screenshot of the SMTP configuration and the version of DCE that you are using?
-Gavan
(CID:153944209)
Can you go to https://DCE_SERVER_ADDRESS/nbc/status/Troubleshoot and try to ping stmp.gmail.com to confirm that your server can resolve the correct address.
Also as previously requested can you confirm the version of DCE you are using?
-Gavan
(CID:153944233)
Dear Gavan,
Thanks for your response,tomorrow I will check ping response and i m using DCE 7.6.0.
(CID:153944243)
Dear Gavan,
Can you please confirm root ID and password of DCE.
(CID:153944357)
Port 587
SSL enabled
With respect.
(CID:153944444)
Dear spezialist
Thanks for your support. My issue has been resolved.
Regards
MS
(CID:153945651)
Ok, very thanks for the good feedback π.
(CID:154402850)
Hi Muhammad,
We can not give out the root password to DCE servers , sorry.
Did you confirm if you can ping?
-Gavan
(CID:153944458)
Posted: β2020-07-06 01:01 AM . Last Modified: β2023-10-22 02:00 AM
