Email setting issue
EcoStruxure IT Forum
  • Re: Email setting issue
Cory_McDonald
Cory_McDonald Champion
160
Jef
Jef Leader
114
gsterling
gsterling Mentor
77
Back to EcoStruxure IT Forum
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-06 01:00 AM . Last Modified: ‎2024-04-02 11:22 PM
2805
Email setting issue
Dear team,
I am trying to configure DCE email notification using smtp.gmail.com but smtp server is not reachable. You kind support is required and error screenshot is attached.
(CID:153944202)
  • Data Center Expert
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-06 01:01 AM . Last Modified: ‎2024-04-02 11:22 PM
2804
Dear Muhammad Shahzad,
According to Michael Hanseman response from post , you must:
I would use Gmail for testing. If you don't have a Gmail account already, it's free and easy to set one up.
Settings you need for the device.
smtp.gmail.com
Port 587
SSL enabled
Username and password.
Depending on the environment you may need to open port 587 outbound on the customer firewall/UTM.
Hope this helps you.
With respect.
(CID:153944444)
Replies 10
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Muhammad Shahzad,
Can you please post a screenshot of the SMTP configuration and the version of DCE that you are using?
-Gavan
(CID:153944209)
DCIM_Support
DCIM_Support Mentor
Mentor
PFA for your review.
(CID:153944227)
DCIM_Support
DCIM_Support Mentor
Mentor
Can you go to https://DCE_SERVER_ADDRESS/nbc/status/Troubleshoot and try to ping stmp.gmail.com to confirm that your server can resolve the correct address.
Also as previously requested can you confirm the version of DCE you are using?
-Gavan
(CID:153944233)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Gavan,
Thanks for your response,tomorrow I will check ping response and i m using DCE 7.6.0.
(CID:153944243)
DCIM_Support
DCIM_Support Mentor
Mentor
Dear Gavan,
Can you please confirm root ID and password of DCE.
(CID:153944357)
DCIM_Support
DCIM_Support Mentor
Mentor
2805
smtp.gmail.com
Port 587
SSL enabled
With respect.
(CID:153944444)
DCIM_Support
DCIM_Support Mentor
Mentor
In response to DCIM_Support
Dear spezialist
Thanks for your support. My issue has been resolved.
MS
(CID:153945651)
DCIM_Support
DCIM_Support Mentor
Mentor
Ok, very thanks for the good feedback 😀.
(CID:154402850)
DCIM_Support
DCIM_Support Mentor
Mentor
Hi Muhammad,
We can not give out the root password to DCE servers , sorry.
Did you confirm if you can ping?
-Gavan
(CID:153944458)
DCIM_Support
DCIM_Support Mentor
Mentor
Posted: ‎2020-07-06 01:01 AM . Last Modified: ‎2023-10-22 02:00 AM
