EcoStruxure IT Gateway installation in non-English Windows
  • EcoStruxure IT Gateway installation in non-English Windows
129
72
Posted: ‎2020-07-04 10:12 PM . Last Modified: ‎2024-04-04 03:25 AM
659
Tips on EcoStruxure IT Gateway installation in non-English Windows
For non-English (i.e. non UTF-8 coding language) Windows OS to install EcoStruxure IT Gateway smoothly, please remember to set Tomcat8 with "Dfile.encoding=UTF8" by adding it per below. Otherwise you may receive 404 error when navigating to https://[IP address]/gateway
  1. Double click on the Web Server Configuration shortcut in C:\Program Files\EcoStruxure IT Gateway ==>
  2. Then select "Java" ==>
  3. Then add "Dfile.encoding=UTF8" line in Java Options ==>
  4. Restart EcoStruxure IT Gateway database and gateway in Services.msc
(https://blog.jamesbayley.com/2013/09/09/tomcat-7-on-windows-is-not-utf-8-by-default/)
Ben Lai Eddie Mou Edward Chan Daniel Kwong
(CID:133375617)
  • IT Expert
Hello Winnie Chau,
With the new release of EcoStruxureITGateway 1.5.2, the installer should now correctly configure itself for use in multibyte languages so you will not have to make this change manually.
Thanks for bringing up this issue.
(CID:140219824)
Posted: ‎2020-07-04 10:12 PM . Last Modified: ‎2023-10-22 01:59 AM
