Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
EcoStruxure IT Advisor 9.5.2: Unable to add the Network Ports to Generic Layer 2 Network Gear genome
  • EcoStruxure IT forum
  • EcoStruxure IT Advisor 9.5.2: Unable to add the Network Ports to Generic Layer 2 Network Gear genome
126
65
Back to EcoStruxure IT forum
TechieBala
Lieutenant JG TechieBala Lieutenant JG
Lieutenant JG
Posted: ‎2025-09-10 11:55 AM
245
I am trying to add the Network port details/properties, but Unable to add the Network Ports to Generic Layer 2 Network Gear on ITA 9.5.2. As you can see in the below screen shot, the window does not allow me to expand to view and add the new properties. Is there a workaround for this issue? Screenshot 2025-09-10 205414.png
  • IT Advisor
ATrabert
Lt. Commander ATrabert Lt. Commander
Lt. Commander
Posted: ‎2025-09-24 05:12 AM
In response to TechieBala
181
Hi Bala,
I made a small mistake in my initial steps, change the override scaling behavior to system instead of application, a similar issue with this fix is documented in this thread
https://community.se.com/t5/EcoStruxure-IT-forum/Isusue-with-4K-ITA-client/td-p/193496
another way to test this would be to edit you display resolution settings and set scaling to 100%, then relaunch ITA and it should work correctly.  I'm sorry you can't just resize the window like you would with a regular windows application, but that dialogue doesn't have regular windows size settings and is fixed.
Replies 5
ATrabert
Lt. Commander
Posted: ‎2025-09-11 06:17 AM
229
Hi Bala,
That is most likely related to your desktop display settings and scaling being set over 100%.  You can set the ITA client to ignore this setting if you edit the shortcut or EcoStruxure IT Advisor.exe properties ->compatibility->change high dpi settings-> and check override high DPI scaling behavior
TechieBala
Lieutenant JG
Posted: ‎2025-09-24 04:44 AM
In response to ATrabert
186
Thank you @ATrabert for your response! I tried your suggestion, but the same problem seems to be there. As you can see in the attached screen shots, I am not able to expand the window of the network properties to add the required networks ports. I tried different laptop, and the situation is better.  However, I am not able to expand to enter or add new network properties. Please refer the attached screen shots. Am I doing something wrong? or Is this related to screen resolution? In any case, shouldn't be an option to expand the window size of the network properties pop-up? Why there is no option to expand the properties window when move over my cursor on the options? Thanks for your time in looking in to this request.
ATrabert
Lt. Commander
182
Hi Bala,
TechieBala
Lieutenant JG
Posted: ‎2025-09-25 12:57 AM
It works now @ATrabert ! Thanks again for your help! Have a nice day!!
ATrabert
Lt. Commander
Posted: ‎2025-09-25 05:26 AM
you're welcome!  somewhat of a common issue with ITA, especially on laptops
