Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
First time login
  • EcoStruxure IT forum
  • First time login
126
65
Back to EcoStruxure IT forum
Hsin
Hsin
Cadet
Posted: ‎2025-09-22 01:04 PM
120
First time login
Hi Team,
I just built a 8.3.0.91 version server on VMWare.
However, when try to login with https://IP, the apc/apcsetup accounts are not working, give error as:
The username and/or password entered is invalid.
But once using console, can login without issue.
I may missed something here?
Admiral
Posted: ‎2025-09-23 06:15 AM
Hello @Hsin,
The only account by default that you can use to access the web interface for desktop client for Data Center Expert is the admin account created within the apcsetup script. The apcsetup, apcinfo, and apcreset accounts are only used for console access, similar to how you used acpsetup to configure the IP address settings.
If the password is not working that you assigned when you created the admin account, you can follow the password reset instructions: https://community.se.com/t5/DCE-FAQ/How-to-reset-the-DCE-Administrator-password-for-the-desktop-and/...
Kind Regards,
Cory
Admiral
Hello @Hsin,
Kind Regards,
Cory
Hsin
Hsin
Cadet
Posted: ‎2025-09-24 05:57 AM
Thanks for the update, we finally login with apcadmin and default password, it just took long time to accept the login attempt.
