Posted: 2020-04-01 03:25 AM
Hi Team
My customer is using a 4K display and when the resolution is set to 4K, the labels in the rack is enlarged compared to using the client at a smaller resolution. Please see attached screenshots.
Best regards
Tonny Keinicke
Posted: 2020-04-01 03:45 AM . Last Modified: 2020-04-01 06:13 AM
Hi Tonny,
Which browser are you using? please try with Chrome, if haven't done that already.
We have recently experienced that the web-client may have unexpected behavior on high resolution screen setup. This has been captured in our backlog for investigation. In the mean time I would go for lowering the screen resolution and/or lower the displayed browser window.
Kind regards
update:
I've just noticed (from your screen shoots) that you are seeing the issue on desktop client, wondering if the following change could help a little. Assuming the Display size is set to 100%. Right click on the application/EcoStruxure IT Advisor shortcut (on your windows desktop) Properties > Compatibility > Change high DPI settings > and then click/enable "Override high DPI scaling behavior. Scaling performed by: select "System" from the list. and OK,
Hi Tonny,
Kind regards
update:
