Downflow CRAC kW limitation
  • EcoStruxure IT forum
  • Downflow CRAC kW limitation
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 09:38 AM . Last Modified: ‎2024-04-10 01:09 AM
689
I am trying to model a 125kW downflow CRAC but the software seems to limit the cooling to 99.9 kW.
Is there a way around this or a different way to model it?
(CID:93193609)
  • Data Center Operation
Replies 5
Which version of DCO are you using? On my 7.4 there doesn't seem to be any (practical) limitation.
(CID:93193613)
Posted: ‎2020-07-02 09:39 AM . Last Modified: ‎2024-04-10 01:09 AM
689
Christian,
I am also on 7.4 and when I try to enter 125kw, it changes the number to 12.5
When I try to increase the number manually by pressing the up arrow, it stops at 100.00
(CID:93193616)
From your screen shot it seems like you're editing the properties from the genome library? As Breda suggest, place it on the floor first. Then the limitation disappears.
(CID:93193630)
I believe this is limited to 100 kW. There is an enhancement request in the system for this.
Work around: add the device/Downflow CRAC to your room, and then change/set the "Cooling capacity".
Breda
(CID:93193620)
Posted: ‎2020-07-02 09:39 AM . Last Modified: ‎2023-10-31 10:55 PM
