Does NBES0201 still is supported by netbotz?
  • Does NBES0201 still is supported by netbotz?
126
65
Posted: ‎2020-07-06 01:13 AM . Last Modified: ‎2024-04-02 11:18 PM
1207
Does NBES0201 (APC NetBotz Particle Sensor PS100) still is supported by some netbotz appliance or sensor pod?
According  to installation manual, it needs a 6 Pin port, and as afar as i know there is no such port available on any current sensor port.
https://download.schneider-electric.com/files?p_File_Name=ASTE-6Z5S83_R0_EN.pdf&p_Doc_Ref=SPD_ASTE-6...
(CID:154403198)
  • IT Expert
  • NetBotz
Victor Juarez Velazquez,
There is no solution that can be sold for the NBES0201 particle sensor.  It required a V2 appliance or a Sensor Pod 120, both of which are end-of-sale and end-of-support.  There is no current NetBotz Solution that can be sold for a particle sensor.
You may be able to find a third party sensor that can communicate via: 4-20mA, 0-5V, or dry contacts; but I have not looked into a possible integration that way.
Cory
(CID:154403201)
Cory
(CID:154403201)
So clear
(CID:154403508)
Posted: ‎2020-07-06 01:13 AM . Last Modified: ‎2023-10-22 01:55 AM
