Different colour code for each UPS source
Showing results forΒ
Did you mean:Β
  • Different colour code for each UPS source
129
72
Posted: β€Ž2020-07-03 12:12 AM . Last Modified: β€Ž2024-04-09 12:59 AM
1761
Hi Team,
Currently we can only represent different colour code for either source A or source B only.
Customer requested to have different colour to represent different UPS source, to make it easier for their operator to identify which rack / rack PDU is supplied by which UPS at DCO's power tab.
Is this something we can feedback for feature or, what is the take on representing power source with colour?
Chris
(CID:105466416)
  • Data Center Operation
Posted: β€Ž2020-07-03 12:13 AM . Last Modified: β€Ž2024-04-09 12:58 AM
I have been working with Chris on this and we are able to show 4 colours on the same rack. Here is an example.
Thank you.
(CID:105466884)
Replies 7
Hi Chris I am not sure I understand the question. Each UPS can have a different color and that color is used to color racks and rack PDUs throughout Operation. The colors should not be limited to one for A-feeds and one for B-feeds. Can you perhaps provide a screenshot that gives an example of the limitation? Best, Niels
(CID:105466964)
Hi Niels, my bad, upon further checking on the setup, the power indeed follow UPS. Chalk it to my mistake on configuring wrong power source πŸ˜•
(CID:105466967)
I wonder how DCO show a rack with 4 rpdus (2 source A, 2 source B)....Need to test this out
(CID:105466966)
Glad you figured it out!
(CID:105466968)
Christopherus Laurentius You can see in this video how the power path represented with color in racks, PDUs and ATS: https://www.youtube.com/watch?v=DrsXcDYo_34
(CID:105466965)
Thank you.
(CID:105466884)
