Dear Community Members,
We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience.
SE Community Team!
invalid thread access has been found in 7.5.
  • EcoStruxure IT forum
  • invalid thread access has been found in 7.5.
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 12:13 AM . Last Modified: ‎2024-04-09 12:58 AM
782
Whilst fixing a duplicate key error in 7.5, an invalid thread access has been found which needs further investigation. Fredrik Madsen asked me to log this as another issue.
(CID:105466429)
  • Data Center Operation
Posted: ‎2020-07-03 12:14 AM . Last Modified: ‎2024-04-09 12:58 AM
Hi Pete,
Few days ago I informed you that according to the kindly provided logs, this seems to be what has been experienced:
Client application refreshes search in equipment browser, which involves doing a server side request in order to get results not loaded into the client. The server search does not succeed since the client gets "connect timed out". Error handling continues to update the equipment browser contents - but not using the same context as a normal result response from the server. Due to a bug in the error handling the client encounters "Invalid thread access".
After initiating a new search the equipment browser should contain the right results.
If the issue should be seen repeatedly then our team could create a patch - but it is unexpected to see this issue repeatedly, since it is only an error handling issue.
Kind regards
(CID:105467484)
Replies 5
thank you Pete, we are investigating it now.
(CID:105466984)
Hi Pete,
Kind regards
(CID:105467484)
782
ok, thanks for the response, we will keep an eye on it and come back to you if there are any further issues.
(CID:105467486)
Hi Pete, You are most welcome, thanks. Kind regards
(CID:105467487)
Posted: ‎2020-07-03 12:14 AM . Last Modified: ‎2023-10-31 11:10 PM
