Detected an unauthorized user attempting to access the SNMP interface
  • EcoStruxure IT forum
  • Detected an unauthorized user attempting to access the SNMP interface
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 04:00 AM . Last Modified: ‎2024-04-05 03:08 AM
3613
I have a customer that is receiving a cascade of alerts when his monitor servers ping his network management card.
I know he can disable this alert but then he won't be able to receive notification in the event of a genuine malicious attack.
Is there any way to put is server on a white list to prevent these nuisance e-mails.
(CID:128065151)
Posted: ‎2020-07-04 04:01 AM . Last Modified: ‎2024-04-05 03:08 AM
3612
Dear Adrian Carroll,
As Steven Marchetti correctly answered, a similar question :
Your first best bet would be to stop the scanning with incorrect credentials...
I.e., in your case, your 3-rd party monitoring server should poll the NMC by the SNMP protocol with the correct community strings (see the settings inside the NMC in the SNMP section).
I hope this is what you need.
With respect.
(CID:128065174)
Replies 6
3613
With respect.
(CID:128065174)
Hi ,
The path given by Steven is the path from the DCE. Is there a way to find out the correct community strings from the NMC itself?
(CID:128065951)
Posted: ‎2020-07-04 04:01 AM . Last Modified: ‎2024-04-05 03:07 AM
...Is there a way to find out the correct community strings from the NMC itself?
Yes, of course.
I explain for SNMPv1: in order for NMC not to flood you with e-mail messages about unauthorized SNMP access attempts, you need to specify the correct Read-only Community Name on your 3-rd party monitoring server for your NMC (please, contact the administrators of this 3-rd party monitoring server).
For example, you need login to the web-GUI of your NMC along the path as in my screenshot (for SNMPv1):
And then we'll see, that for this NMC Read-only Community Name = public (this is the default value, I did not change it, although I could do it). Now, this value, i.e. public must be specified on the 3-rd party monitoring server to poll this your NMC.
If on your 3-rd party monitoring server to poll this NMC is specified the incorrect value of Read-only Community Name, it causes a lot of e-mail messages from the NMC about unauthorized SNMP access attempts.
I hope I understood you correctly and it will help you.
If there are more questions, please ask.
(CID:128065948)
That's great. Thank you very much for your assistance.
(CID:128065943)
Ok, thanks for the feedback 😀.
(CID:128065938)
Posted: ‎2020-07-04 04:01 AM . Last Modified: ‎2023-10-22 01:52 AM
