Dco 8.2.12 integration with BMS (EBO 1.9)
  • EcoStruxure IT forum
  • Dco 8.2.12 integration with BMS (EBO 1.9)
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 06:30 PM . Last Modified: ‎2024-04-03 02:58 AM
879
Can Dco 8.2.12.integrate with BMS (EBO 1.9) via EWS?
What AI know is that, the only way for this integration will be via ETL and in this case the EBO should install a report server with SQL server so that we can extract data from SQL, anyone has an experience with integration like this ?
BR,
Sameeh
(CID:141268643)
  • Data Center Operation
Replies 6
We did a few SBO to DCO via EWS, mainly to get power and temperature data in data center.
e.g sensor data can be associated to rack PDU for measured power, temperature sensor etc
Do contact CSP team Søren Bruncke Mikkelsen and Rune Østergaard for the ETL required to consume EBO data (per explained above) via EWS.
(CID:141268773)
Hi Chris,
Thank you for your reply, but what I understood before is that I have two options for integration from (EBO) to (DCO) :
A) Either via ETL ( and in this case I need to create tranformation file to extract data from source (EBO) then load it to the target system (DCO).
2) Or,  via EWS and in this case there is no need for extra work or ETL( sucah as consuming data from DCE to EBO) please correct me if I am wrong.
BR,
Sameeh
(CID:141268971)
The ETL is to pick up data from SBO/EBO via EWS.
I don't think DCO can consume EWS directly.
(CID:141269011)
Hi Sameeh ahmad,
Did you find an answer to your question?
Stine
(CID:143263577)
Posted: ‎2020-07-05 06:31 PM . Last Modified: ‎2024-04-03 02:58 AM
Sameeh
You are correct that DCO does not support EWS directly. The EWS integration method would be with DCE and then DCE feeds DCO. Data can be brought in via ETL to DCO also as you have pointed out.
(CID:143264878)
Posted: ‎2020-07-05 06:31 PM . Last Modified: ‎2023-10-22 01:51 AM
