Posted: β2020-07-05 04:23 PM . Last Modified: β2024-04-03 05:07 AM
Hi All
with a new DCO v8.2.12, backup and restore are moved to web client.
What happen if Web client doesn't work?
From webmin i can import a file but how can i restore it?
in the previously release we were able to do backup and restore from webmin
thanks a lot
(CID:138807623)
Hi Gianluca,
That's a good question. If the web client doesn't work, then some trouble shootings may be needed. So simply restoring a backup file might not be the solution.
However if the server should be in bad state, then a clean installation + restoring a back file may be the best option.
Kind regards
(CID:138807664)
Posted: β2020-07-05 04:23 PM . Last Modified: β2023-10-22 01:51 AM
