Client-server communication error
  • Client-server communication error
129
72
Posted: ‎2020-07-05 04:22 PM . Last Modified: ‎2024-04-03 05:07 AM
1703
Every time i try to update power dependency for an inrow i get this massage.
When i update the same thing for  a PDU everything works just fine.
(CID:138807446)
  • Data Center Operation
Posted: ‎2020-07-05 04:23 PM . Last Modified: ‎2024-04-03 05:07 AM
1703
For now we solved the problem by restoring a two days old version of the VM
(CID:138807585)
Replies 7
And now this massage after client reboot
(CID:138807461)
And now I cant even load the client.
I get the "Client-server communication error" in the module loading stage.
(CID:138807478)
And that is what i get when trying to load a room via web:
(CID:138807488)
Hi Eitan,
Can you provide the following data:
1- copy of the latest database/backup file
2- client application.log file
    (usually located in C:\Users\\.isxo\8.2*\Operations\application.log)
3- server logs
4- location of the issue equipment, please also include if you have/had managed to capture screen shots illustrating the device and its power config.
I will send you an invite to my =S= box folder, so the data safely can be shared with me, thanks.
Kind regards
(CID:138807577)
1704
(CID:138807585)
Hi Eitan,
Sounds fine, many thanks for the update.
Kind regards
(CID:138807587)
Posted: ‎2020-07-05 04:23 PM . Last Modified: ‎2023-10-20 05:08 AM
