Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-06-10 05:02 AM
According to picture attached Data Center Expert is able to be deployed on several VLAN segments:
1. Do you have some recommendations to run DCE on a scenario where there would be several VLAN segments? (DCE Server will have one segment & monitored equipment will have other VLAN)
2. Do you have some recommendation to run DCE and avoid roadblocks with firewalls and server management?
3. The bottom line is we will implement it on a retail scenario where there will be spread locations with multiple VLAN segments
Thank you in advance.
Posted: 2020-06-10 06:15 AM
Hi!
There is nothing special.
Customer should provide proper inter-VLAN routing on Corporate LAN and open ports on firewalls.
Here some info about this:
https://dcimsupport.ecostruxureit.com/hc/en-us/articles/360039289633-Data-Center-Expert-Security
Hi!
