Data Center Expert - How to Enable Surveillance for a NetBotz Camera
  • EcoStruxure IT forum
  • Data Center Expert - How to Enable Surveillance for a NetBotz Camera
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 05:39 AM . Last Modified: ‎2024-04-08 11:16 PM
696
Video Knowledge Base: http://www.schneider-electric.us/en/faqs/FA297815/
1) Log into the StruxureWare Data Center Expert Client.
2) Ensure that the NetBotz Appliance with the Attached camera is showing within StruxureWare Data Center Expert.  If it has not been discovered yet, please reference FA177081.
3) Each NetBotz Camera requires one Surveillance license.  You can verify the licensing that you have installed by: System Menu > Server Administration Settings > License Keys.  There will be a specific License Type of StruxureWare Data Center Expert Surveillance Pack along with a node count and used node count for that license.
4) Select the Surveillance perspective.
5) Right click on one of the camera thumbnails and select Surveillance Settings.  *TIP: You can select multiple thumbnails by CTRL+click or SHIFT+click on the camera images.
6) Mark the check box for License Camera.
7) Enter the StruxureWare Data Center Expert Server's IP address and configure the security, if the appliance was discovered using SSL or if the NetBotz can only communicate using SSL.
😎 Select the Post Mode that you would like to record the Surveillance clips for.  There are other options to configure, if deemed necessary.
9) Select Apply and OK.
(CID:108235368)
  • NetBotz
Posted: ‎2020-07-03 05:39 AM . Last Modified: ‎2023-10-31 10:23 PM
