Posted: 2024-02-14 11:44 AM
The Data Center Expert 8.1.0 release contains improvements including:
The public REST API is now available at https://<server_address>/isxg/rest
The Data Center Expert Virtual Appliance OVA is now built on ESXi 6.7.
Only E1000E and VMXNET3 network adapters are supported.
Event log messages can now be forwarded to a Syslog server. Go to System > Server Administration Settings > Syslog Configuration to enable Syslog integration and configure settings.
The event log now includes:
There is a new $(SENSORVAL_NOLABEL) alarm action macro that does not include special characters.
When you configure the Short Message Email alarm action, you can replace the default $(SENSORVAL) macro in the Subject and Message fields with $(SENSORVAL_NOLABEL) to display the sensor value without the label, for example, 81.2 rather than 81.2 ° F.
You can now customize device labels for SNMP and Modbus devices. Right click the device and select Device Label Settings.
The Data Center Expert server now checks the available disk space before performing a software update and before restoring a backup.
The loading time for the list of backups was optimized.
Obsolete options were removed from the desktop client:
Posted: 2024-02-14 03:17 PM
Hi, is this new version available for the SFDCEVM as currently i'm not seeing any software updates in EcoStruxure IT Entitlements Portal.
Posted: 2024-02-16 10:40 AM . Last Modified: 2024-02-16 10:41 AM
Yes, the DCE VM trial software for DCE 8.1.0 is available. Here's a link to an updated article for that:
https://community.se.com/t5/DCE-downloads/DCE-VM-trial-version-download-links/ta-p/446780
The product page on the web will be updated for version 8.1.0 soon. The link to the VM trial is not on the downloads page in the Entitlements portal. That's not a bad idea, though!
Posted: 2024-02-27 07:55 PM
HI,
Since DCEv8.1 have REST API, does the SOAP API still will be supported? if Yes, how long SOAP API will be supported?
Thank you.
Posted: 2024-02-28 05:39 AM
Hi @sesa272783 ,
There is no plan for soap to go anywhere. There are too many integrations that would break if it did. It's going to be around for the foreseeable future.
Steve
Posted: 2024-03-21 09:08 AM
Hi!
We've faced with an issue with configuration backup: it doesn't work when storage usage is more than ~9.5GB. Full backup works.
We use NFS for backups.
Does anyone have the same issue?
thanks!
Posted: 2024-03-26 09:43 AM
Hi @AlexM,
If you haven't already, I suggest that you contact your local technical support for help. https://www.apc.com/support/
Posted: 2024-04-29 04:27 AM
Are you sure about SOAP?
DCE (8.0.0) and EBO 2022 (v4.0)
DCE serve information to ITA and EBO. There are no direct connection to device form EBO.
The system was working properly. After update to 8.1.1, EBO lost communication with DCE by EWS.
After create new VM v8.0.0 and restored from backup, communication with EBO via EWS back to normal.
How fix the issue in version 8.1.1?
Posted: 2024-05-28 12:13 AM
Same issue
Posted: 2024-05-28 10:27 AM . Last Modified: 2024-05-28 11:21 AM
Hi @PrzemekSz
There is an issue with the EBO integration after updating DCE 8.0 to 8.1 or 8.1.1. This will be addressed in DCE 8.2.
Please see https://www.apc.com/us/en/faqs/FAQ000267255/
