DDF. not same value.
  • DDF. not same value.
129
72
Posted: ‎2020-07-03 10:03 AM . Last Modified: ‎2024-04-08 02:41 AM
1497
hello.
i have ddf file.
xxxx.xml
install dce.
but.
not same value.
snmp view from web page. temp is 24.4 C
but snmp view from dce.
temp is 244.0 C
why  *10 Value?
how fix it?
help me please.
thanks.
(CID:110017664)
  • DDF
Replies 8
Posted: ‎2020-07-03 10:04 AM . Last Modified: ‎2024-04-08 02:41 AM
1496
Dear Yongjin,
It looks to be scaling issue in the DDF. If you received the DDF file for your third party device from EcoStruxure IT Help Center-device support request, then please contact them again with DDF reference number so that they can modify the DDF to show you the correct scaling of the Temperature Sensor in DCE software.
Bala
(CID:110017677)
Thank you Bala
(CID:110018039)
Hi Yongjin Choi,
Structure of the DDF-file not so difficult: necessary corrections can be made independently. I can help with it.
(CID:110017754)
Posted: ‎2020-07-03 10:04 AM . Last Modified: ‎2024-04-08 02:40 AM
Very thank you spezialist
I am using notepad. And i have an xml file.
Contents of xml file are below.
What should I fix ?
http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://localhost/ddf_schema/apc_ddf_1_6.xsd" ddfid="FLSystem_FLS7100A" ddfname="FLSystem FLS7100A" ddfversion="1" canremove="yes">
1.6
FLSystem
FLS7100A
Cooling Device
humidity
_Setting Humidity
.1.3.6.1.4.1.22210.2.1.2.0
1
DDC400
temp
_Temperature
.1.3.6.1.4.1.22210.2.1.3.0
1
DDC400
humidity
_Humidity
.1.3.6.1.4.1.22210.2.1.4.0
1
DDC400
temp
_Cooling Error
.1.3.6.1.4.1.22210.2.1.5.0
1
DDC400
temp
_Heating Error
.1.3.6.1.4.1.22210.2.1.6.0
1
DDC400
humidity
_Humidity Error
.1.3.6.1.4.1.22210.2.1.7.0
1
DDC400
humidity
_deHumidity Error
.1.3.6.1.4.1.22210.2.1.8.0
1
DDC400
temp
_Setting High Temperature
.1.3.6.1.4.1.22210.2.1.44.0
1
DDC400
state
_Cooling Driving Status
.1.3.6.1.4.1.22210.2.1.9.0
stop_run_em
DDC400
state
_Heating Driving Status
.1.3.6.1.4.1.22210.2.1.10.0
stop_run_em
DDC400
state
_Humidity Driving Status
.1.3.6.1.4.1.22210.2.1.11.0
stop_run_em
DDC400
state
_deHumidity Driving Status
.1.3.6.1.4.1.22210.2.1.12.0
stop_run_em
DDC400
state
_Output Fan Status
.1.3.6.1.4.1.22210.2.1.14.0
stop_run_em
DDC400
state
_Output Comp1 Status
.1.3.6.1.4.1.22210.2.1.16.0
stop_run_em
DDC400
state
_Output Comp2 Status
.1.3.6.1.4.1.22210.2.1.18.0
stop_run_em
DDC400
state
_Output Heater1 Status
.1.3.6.1.4.1.22210.2.1.19.0
stop_run_em
DDC400
state
_Output Heater2 Status
.1.3.6.1.4.1.22210.2.1.20.0
stop_run_em
DDC400
state
_Output Heater3 Status
.1.3.6.1.4.1.22210.2.1.21.0
stop_run_em
DDC400
state
_Output Heater4 Status
.1.3.6.1.4.1.22210.2.1.22.0
stop_run_em
DDC400
state
_Output Heater5 Status
.1.3.6.1.4.1.22210.2.1.23.0
stop_run_em
DDC400
state
_Output Humiditifier1 Status
.1.3.6.1.4.1.22210.2.1.24.0
stop_run_em
DDC400
state
_Output Water Supply Status
.1.3.6.1.4.1.22210.2.1.25.0
stop_run_em
DDC400
state
_Output Water Drain Status
.1.3.6.1.4.1.22210.2.1.26.0
stop_run_em
DDC400
state
_deFan Driving Status
.1.3.6.1.4.1.22210.2.1.45.0
stop_run_em
DDC400
state
_Output Humiditifier2 Status
.1.3.6.1.4.1.22210.2.1.46.0
stop_run_em
DDC400
state
_Fire Fighting Status
.1.3.6.1.4.1.22210.2.1.47.0
stop_run_em
DDC400
state
_Cracoperation Status
.1.3.6.1.4.1.22210.2.1.48.0
run_stop_em
DDC400
1
1
.1.3.6.1.4.1.22210.2.1.13.0
Total Alarm Status Alarm Present
Total Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.29.0
Over Current Alarm Status Alarm Present
Over Current Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.30.0
High Temp Alarm Status Alarm Present
High Temp Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.31.0
Water Supply Alarm Status Alarm Present
Water Supply Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.32.0
Low Current Alarm Status Alarm Present
Low Current Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.33.0
Comp1 Alarm Status Alarm Present
Comp1 Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.34.0
Comp2 Alarm Status Alarm Present
Comp2 Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.35.0
Heater Alarm Status Alarm Present
Heater Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.36.0
Water Level Alarm Status Alarm Present
Water Level Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.37.0
Humiditifier Alarm Status Alarm Present
Humiditifier Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.38.0
Fan Alarm Status Alarm Present
Fan Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.39.0
Leak Water Alarm Status Alarm Present
Leak Water Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.40.0
Temp Sensor Alarm Status Alarm Present
Temp Sensor Alarm Status Alarm Cleared
warning
system
.1.3.6.1.4.1.22210.2.1.41.0
Humidy Sensor Alarm Status Alarm Present
Humidy Sensor Alarm Status Alarm Cleared
warning
system
(CID:110018038)
Team-I would suggest not to edit the DDF files format based on my practical implementations at the site. Improper format of DDF may causes problems to the DCE performances in the future. I agree DDF format is simple, and easy to edit, but often we may not be able to verify on how the reference was taken. DDF team can surely help you in editing the DDF for you based on the issues that you report in continuous to your DDF reference number.
As far as I know, DDF team has got the right software tools to make changes and simulate the results as well.
This way, you can also be sure that the DDF which you are using is the correct one.
(CID:110018062)
1495
Hi Yongjin Choi,
In above the specified DDF-file it is necessary to make corrections here (under .1😞
temp _Temperature .1.3.6.1.4.1.22210.2.1.3.0 .1 DDC400
The logic seems to me is clear and it isn't necessary to explain in detail. Or it is necessary?
It is supposed that you are a professional and you won't make silly mistakes about which warns Balaraman Jagadeesan.
Always I am glad to help practically.
(CID:110018139)
Sorry.
I work. Without internet.
thank you.
I fix it.
(CID:110019539)
Posted: ‎2020-07-03 10:04 AM . Last Modified: ‎2023-10-22 01:49 AM
